you probably changed the firing order... find TDC for #1 cylinder, and start from there. it does not matter where #1 is on the cap, as long as the order is correct.
making it match the service manual picture, assumes nobody has never moved the dist. somebody probably has....
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
