They called me today to give me an update. I've got one of the first 10 that they cast. Its coming along..............
So when is your date for pick up/ or ETA and
when did you put you order in.. thanks...
and what did you order
I ordered it in July with the understanding that I would get it in the spring. Honestly I probably won't need it till at least summer.
I ordered it as a rotating short block. It is a RB and will be a 512 cubic inch with Molnar crank and rods. This is a street/strip build with target of 650 hp. Its getting a set of Todd Marsh side winder heads. Pretty tame build.
The first motor of the 10 is machined and assembled. Getting ready to hit the dyno - they want to verify all is good before machining the rest of them.
At this time getting the motor in the spring is probably realistic based on current info.
