Hopefully they can be able to continually have them going through the process.
I'm sure the BB Mopar crowd will be timid about laying down big deposits initially, which means the cash flow for MM may be a bit tough in the early going of this endeavor...... But I think in the end it will be a case of "if you build it, they will come".
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
