Thanks for comments guys. I got the car home last night and could not be happier with the job Gary did on the cage. He was able to execute every little subtlety that I requested on it. The tin in the back will not need to be removable so plan is paint or powdercoat then they will be riveted in after cage is painted. The pictures really don't do it justice, the dash bar between the A pillar bars is a work of art. I can still drop column if needed and remove dash if needed and there is still room for the small vintage air unit and the hidden wiper motor. Glove box door is still functional minus the cardboard box, that will make a nice location for a panel to mount the Dominator EFI.
