Something I've been wondering, when doing Ehrenberg's recommendation of hooking the alt output directly to the bat stud of the starter relay, will that make my alt and v reg constantly live? The alt will constantly have voltage from the battery won't it? I know the v reg is switched with the key in the factory set up. I'm just curious. I'm thinking that my charging issues are the result of a wiring harness problem.
