field wires switched on alt field terminals-no problem. blue/green switched on reg-big problem (if it full fields tho likely it would just be a no charge which is far better than full fielding), tho not likely on them cuz the reg triangle connector/pigtails are blue/green. holler back. EDIT blue goes to either alt field terminal and to the "top" reg triangle terminal with it facing up like a pyramid. green goes to the "side" reg terminal and the other alt field terminal.
