My comps had the oil hole inline. The motor would only build 45psi@7000. epoxied the hole in the adjacent side of the lifter and restricted the opposite side to .040". Then had to back the adjustment screw for the relief valve out .250" to get the pressure back down to 65@7000.
Doug
