How does the oil get from your .060 hole in the bushing into the slot on the lifter body?
Unless I'm missing something, this really doesn't look like it's going to provide proper oiling on a mopar.
I would much rather see a full diameter oil band on the lifter body, that's getting pressure from the feed hole 100% of the time, then have edge orifices above the band in line with the axles.
On the motors I've done with spray bar oiling, I have one .060 restrictor per side.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
