Originally Posted By Monte_Smith
If those cool billet arms are aluminum and are supposed to bolt on the end of a piece of steel tubing as the anti-roll. It WILL eventually elongate the hole in either the tubing, the arm or both and you have slop. At that point the anti-roll is useless
No they are steel. Need to be welded onto 1.5" tubing. I have a Chassis Engineering Top Gun ARB for my RoadRunner. Arms are fully welded. The billet arms would save a lot of welding time over the TG piece.
69 GTX 68 Road Runner
