^^^^^^^^^^^^^^^Don't waste your time on moving shocks to front. Helps or solves nothing.
To OP, YES to anti roll, but not one like in above pic. Any bar that has the ends bolt on will eventually cause a problem when it wallows out the holes........which it WILL. Arms should ALWAYS weld on to tube
