didn't Hughes or someone have a 2 piece tray ? was a lot of complaints of leakage at overlap . that may be the hardest area to seal ? maybe the folded edge will help this by being stiffer . maybe have a threaded bar spot welded to the plate rather than use sheet metal screws at least then they wont tear out
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
