I've sent a couple of emails to Trick Flow telling them they need to do a high port version of the head. There is a lot of material there so it should be fairly easy to do. Just move the ports up as they move them out. If they would extend the intake face by 1/2 inch and move the ports up 1/2 inch the head would flow better and they would get rid of the bathtub gasket and all of the associated issues.
They never responded to my emails so I doubt they'll take the advice but it would make the head an even bigger winner. Standard intakes would still bolt on, they would just be raised up a slight amount. The port would be the same size but it would be a straighter shot to the valve rather than an S shape like it is now.
But regardless of what they do, I have a solution for the valley tray issue. I have a design ready to get cut and should have parts on my engine to test before too long.
