Are the ports raised or significantly larger that an oe pan wont work? I had some stage 6 heads that the ports were raised higher than stock stage 6s. I made a factory style, port encircling pan for that set up. not a big deal for me. Seems that if a special pan is needed it would be very easy to have made. I have access to a laser and brake. Let me know if this is something that needs to be on the market.
