I run close to your times, 10.30 at 130 . I just have stock Monro shocks up front, got tired of changing oil pans. Launches with the wheels up as pictured , shift before the 60 foot. 60 ft times are 1.47 . Launch at 4,700 shift at 6,800 3.25 low gear, 4.56 rear with 11.5 29.5 W Hoosiers. Low compression 505 pump gas engine.
it's ok to butt heads, just don't do it with a butthead
