Well my opinion isnt worth much, but you can have it for free..
The reason I would not go with the Victor or any other High rise intake is that the motor is mostly street, and that engine and cam wont RPM very high. Im guessing 5600-5800 and she's all done. Those intakes just work better on 6K and higher engines, but the good side is that if you do use one of those intakes, it might hook better on the street, do to the loss in torque..
The Holley SD would be a good intake, and If I could pick one up fairly cheap...that would be the way to go also.
