hi there,
I have a 400 stroked to a 515 ci from 440 source, i too have the stealth heads. I also think i m close to the 560 lift as well. I ll be using the toker II intake on my set up. Your barcuda is alot lighter then my 74 charger. So you should get moving pretty quick. I d suggest on at least a 3500 rpm stall TQ in the tranny. As for carbs, well i have a few choices, a 650 holley, and an 850 demon. But i may have to get something bigger. If you have any pics send them over to my e mail.
