I had the upper control arms and the spindles mounted when I did mine. Also my first time. I had the lower control arm in for the install. It does work very well. I just thought it was easier to have as much together as possible. After the motor and tranny install when you install the torsion bars remember to have some load(as little as possible) on the lower control arms. This allow for the maximum adjustment.
Good luck
There are pictures in my signature site under motor and install.
