Alan, my upper control arms are already in (loosly). Will I need to remove them to get the upper ball joint into the steering knuckle?
No...Once the K frame and transmission crossmember is secure you can carefully raise the lower control arm/brake assembly to meet the upper ball joint....This is much easier if done BEFORE the torsion bars are installed.
