Originally Posted By DAYCLONA
If the requirements of the above replies have been met and those issues do not/could not possibly apply, it could be something as simple as too much grease in the pilot hole/bore preventing the input shaft from traveling further into the bore
No lube should be used on the brass pilot bushing.. Dry only
