So, what PSI do you other Edelbrock folks use for your fuel supply? I've heard that they are very sensitive to fuel pressure greater than 5.5 PSI.
i think the psi issue has more to do with the small floats lack of control. the 5-6 psi thing keeps the fuel control happy with the availiable parts. i have run and do run a little higher without issue but i juggle parts.
