Originally Posted By preddy
So, what PSI do you other Edelbrock folks use for your fuel supply? I've heard that they are very sensitive to fuel pressure greater than 5.5 PSI.
i think the psi issue has more to do with the small floats lack of control. the 5-6 psi thing keeps the fuel control happy with the availiable parts. i have run and do run a little higher without issue but i juggle parts.
