The Chrysler transistor ignition systems were the hot setup when they first came out 40+ years ago, but there are a lot better options now. Including converting to the GM HEI control module and an E-coil, which I am doing for the Ramcharger. I have never seen a GM HEI module fail.
I converted the Lean Burn system (another loser) on my '87 truck to a seriously overkill system for a mild 318 and I would never bother with one of the old systems again.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
