I think Ideally you'd want to do something like a pothole deflection test more than anything. Something to actually load the k-frame as the suspension would in a real world condition.
The thing you find often in aftermarket K's is that they have the LCA mounting points pretty far behind the rear k-frame bolt so the load is not spread over the K-frame and especially the factory bolts as it is in the stock setup.
