Originally Posted By BSB67
9/32" drill and some WD-40. Don't know the rpm, just use what felt right. It drills pretty easy.
if you use oil or lube, it tends to make the cuttings into lapping compound and makes the hole oversized, do it dry if the hole is dimension critical
