Muscle Street is basically structured as an "entry level" heads up class.
using a stock block limits the engine displacement.
running "OE replacement" style heads helps keep the costs of the top end down, and should help level the playing field and keep the competition tighter.
personally....i like the rules as they are. if i lived in an area where this class was being run, i would definately participate.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
