i have 1 of those carbs on my 440 . Yep 2 half pumps and will normally fire up dead cold - but will have to hold idle to 900/1000 for about a minute , then will idle roughly till about 130deg eng temp .Will occasionally stall when air is cold when I have backed out of garage and then let idle .By the way mine idles around 900/950 in neutral great carb though
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
