Quote: Well I am 90 percent there. Working the bugs out. It is unreal!!! Faster than my alcohol 9.40 motor on the pump and water/meth with only 7lb of boost.
Need to get painted once the bugs are all worked out. I have put almost 100 miles on it. Rides smooth! Need to put the mesh grill in and do the body work.
I am thinking DP50 satin black. Thoughts?
The satin look would be very cool....PPG makes a single stage industrial paint that is sweet and much better than the DP50 as far as UV is concerned
