Cool, looks good. Wish mine had all that room around front end. I like the way you did the turbo mount also with the T6 flange.
I gotta fix my wastegate I pegged the gauge at 20 PSI twice yesterday
You won't have any trouble spooling that S480, mine is putting out around 3 PSI at 2500 RPM & my exhaust system is way way too big & only 394 inches. Boost is definitely addicting.... turns a mild mannered motor into a video game like animal.
Power? not a problem... keeping it on the road & out of the ditches... may be a problem
