Quote:Quote:Quote:Avoid 96 and later V8 ZJs, they have oddball rear axles. If you get a v8 one, make sure it is '93-95.TJ's are better, LJ is the best in my opinion. What are the differences in rear axles prior and post '96?And the LJ is just a longer wheel based TJ, correct? They were offered between '04-06? The later axles were an aluminum "Dana 44" that nothing interchanges with and has almost nonexistent aftermarket support.
