Finally had some time to do a little work on the car today. Patrick has been pretty busy with work and is also going to school to finish his Masters in engineering. I took time out to buy a house and move.
Raised the steering column up some so it is easier to get in and out of the car. Seat is located, just have to do the final mounting.
Tacked in the gas pedal and test fitted the trans tunnel. Next step is the foot box and firewall. Then the car will come home so I can rewire and plumb it.
