Got Bondobob working on a pair of ball joint sleeves so we don't have to hack up the stock A-arms. I want to stay with the stock spindles because the Monocoque wheels are the metric FWD bolt pattern.
sleeve is 1 inch tall and i recessed the ball joint into it will be alot easyier to tig the 1 inch moly to the sleeves now instead of doing a .600 tall sleeve Bondo
