Went down to Patrick's today and got some more cutting and welding done. I finally pulled the trigger on taking out the stock front frame rails. I just could not figure out how to leave them and not have them look hilljack.
New front frame
Old front frame
Front extensions gussetted on
Just for Quicktree, Keep your Mopar all Mopar
I know hindsight is always 20-20, but if I had to do this again we'd start with an Alston or Jegster front clip kit.
I am very glad to see you removed the stock frame rails! Are you also stretching the wheelbase?? You will be much happier if you do!
Karma has no menu. You get served what you deserve.
