I did scan it. There was not that many options, it was torn into many pieces, you couldn`t touch it or move it. No numbers dissapeared, looks more bright and sharp than before. I don`t expect it should react after it was laminated.
Quote: I was going to post "Dont laminate the sheet!" But I guess Im too late. Be sure to make several high resoloution scans now, sometimes the inks can fade or run when sealed into the plastic like that.
