Re: 71 cuda - 340 lost, what`s the best replacement?
[Re: Delta]
#1711013
12/15/14 09:28 PM
12/15/14 09:28 PM
dogdays
The 340 and 360 are the same engine on the outside.
The original 4-speed will mate to the 360, they were available that way when new. The bellhousing (part that goes between the engine and the transmission) is the same for both.
Make sure that you get a flywheel that matches the engine. By that I mean the flywheel will have 130 tooth ring gear, and have the normal MOPAR 6-bolt flange. But 340s and 360s had different balance. And who knows how a stroker is balanced. So, you need to make sure that WHATEVER engine you buy has a harmonic damper and a flywheel that are balanced to the particular engine you are getting.
For a clutch the flywheel will have a 10.5" pressure plate bolt pattern, and you can use the bigger clutch, they called it 10.95" to differentiate it from the larger flywheel that took either an 11" or 12" clutch. Centerforce Dual Friction would be my choice.
If you can afford aluminum heads they would help take weight off the front end, that would be good. Then also you could run 10.5:1 compression with your available pump gasoline. It should be very easy to make 500 hp with such an engine, if you want that much. If you wanted only 400hp, a 360 would do quite well.
I would suggest finding a builder on the East Coast to build an engine for you. I am suspicious of mass-produced high performance engines.
I hope someone here can give a reference or two.
Whatever you do, ask here before you buy. Or send me a pm, I love to spend other people's money.
Good Luck!
R.
The good news is that you only have to sort this out once.
Entire Thread
Delta
12/15/14 08:53 PM
roadrunninMark
12/15/14 09:08 PM
Delta
12/15/14 11:06 PM
DPelletier
12/15/14 11:13 PM
Delta
12/15/14 11:56 PM
rt66jim
12/16/14 12:15 AM
Dean_Kuzluzski
12/16/14 12:23 AM
6bblgt
12/16/14 12:26 AM
mattsmopars
12/16/14 12:32 AM
d-150
12/16/14 12:37 AM
jose jones
12/16/14 01:19 AM
Grizzly
12/15/14 11:26 PM
JohnRR
12/15/14 10:24 PM
terzmo
12/16/14 12:23 AM
roe
12/16/14 12:31 AM
StrkrDart69
12/23/14 12:59 AM
ScottSmith_Harms
12/23/14 01:04 AM
Delta
12/23/14 01:12 AM
mopar346
12/23/14 01:27 AM
Delta
02/25/15 09:24 PM
dogdays
02/25/15 09:40 PM
Delta
02/25/15 10:31 PM
GO_Fish
02/28/15 08:11 AM
Vert
03/16/15 08:00 PM
GO_Fish
03/21/15 04:48 AM
Delta
03/29/15 03:14 AM
GO_Fish
03/29/15 05:09 AM
d100dragracer
03/29/15 07:49 AM
ScottSmith_Harms
03/29/15 02:20 PM
Delta
10/26/15 11:16 PM
dogdays
12/16/14 01:28 AM
skicker
12/16/14 01:36 AM
beatgoeson
12/16/14 01:49 AM
Delta
12/16/14 02:03 AM
ScottSmith_Harms
12/16/14 03:52 AM
mopar346
12/16/14 04:13 AM
RUNCHARGER
12/16/14 04:16 AM
skicker
12/16/14 06:06 AM
jose jones
12/16/14 06:45 AM
Delta
12/16/14 12:06 PM
floyd
12/17/14 02:54 PM
ErikR
12/17/14 03:57 PM
ScottSmith_Harms
12/17/14 04:56 PM
ErikR
12/17/14 05:26 PM
Delta
12/17/14 11:01 PM
B3422W5
12/17/14 08:07 PM
Delta
12/17/14 11:11 PM
ademon
12/17/14 11:35 PM
ScottSmith_Harms
12/17/14 11:45 PM
Delta
12/18/14 12:20 AM
ScottSmith_Harms
12/18/14 12:29 AM
Delta
12/18/14 01:04 AM
dstryr
12/18/14 01:34 AM
ScottSmith_Harms
12/18/14 04:19 AM
Delta
12/18/14 08:31 PM
ScottSmith_Harms
12/18/14 10:17 PM
FJR doc
12/18/14 10:46 PM
Delta
12/18/14 11:22 PM
mopar346
12/19/14 02:31 AM
mccannix
12/19/14 04:53 PM
Delta
12/19/14 07:17 PM
PasiR
12/19/14 09:40 PM
Delta
12/21/14 12:46 AM
tx9cuda
12/21/14 01:17 AM
ademon
12/21/14 01:25 AM
ScottSmith_Harms
12/21/14 01:48 AM
mopar346
12/21/14 02:27 AM
hemicar1971
12/21/14 06:54 AM
Delta
12/22/14 11:48 PM
B3422W5
03/14/15 01:44 AM
ScottSmith_Harms
10/27/15 04:17 AM
