I recently bought 71 cuda, originally 340 (unfortunattely lost 20+ years ago), not running since. It is 4 speed car, transmission still there. Because of 340 engines are expensive (12k for crate engine), I`m considering to use 408 stroker (360) engine instead, which are around 7k, and they shoudl have more HP. It is my first E-body, have no experience, so here are my questions?
1. will 360 (408) fit without any frame adjustments or adapters to 340 car?
2. will it fit to original 4 speed?
3. any recommendation, where to buy 408 (engine builders, etc...- I found it on Summit and Ebay from ATK)
4. in general, is it smart to use this type of engine? Or would you recommed something totally different?
The reason why I want to keep it small block is because of weight and easy handling.
