I'm glad you guys all have such good luck with them. I sold my 00' at 125k. So far It had 3 injection pumps, 1 transmission, the dash had completely collapsed and the clear coat was coming off all over...
I truly wish it was not had been the case because the engine was fantastic.
Guys realize the weak points and up grade them. The dash is like $200. The injection pump was failing because of the bad factory lift pump. Most guys put a FASS or an Airdog on ASAP. As far as the paint a lot depends on the color. Some hold up much better than others. Almost forgot the trans. If you get a good rebuild with upgraded parts they will last 300,000 miles or more even if you beat them every day.
