Seriously not sure you will see any big gains from a dry sump unless you have a less than optimal wet sump system.
One other thing to think about with a dry sump is packaging. They take up ALOT of room. With a stock K member, or steering cannot be an easy fit. Even with an aftermarket K and rack it was a challenge and very very tight on our 68 Barracuda.
