Quote: Robert, also, that green and red wire you see soldered is actually the light blue/yellow wire at the ECU, I had to extend the wire years ago to re-arrange things for the big block..
Yeah that is correct. did we check what the cranking voltage (with the starter cranking) is at the coil pos pri terminal? I will go back in the posts & see.
