Quote: yes the HEI puts out one hell of a spark but the OE mopar setup will start/run OK & the voltage drop here from the poor electrical connections is making the spark somewhat weaker but blue/yellow should be enough to fire. I would correct the voltage drops so you dont have to use the jumper as the hard components are adequate enough as it does fire when you jump it
according to what ive read, the ballast should bring the voltage do 5.5-6 volts in 'Run', mine is 5.6 in run, so thats fine. The problem is when cranking, it should be 12 volts and its only 7.7. I would like to rewire the cranking circuit so the voltage will be right when trying to start it. Do you know where i would run the new wire?
