all stock wiring. Any ideas where to look?
Is it possible to install the petronix kit into an ELECTRONIC distributor like you can a points unit so i can do away with all the factory crap?
Clean all the terminals on the firewall bulkhead (male terminal NAPA 725147) to clean the female halves and a wire brush for the male ones & koppercoat for continuity/dielectric grease to seal em away from air then as needed check running voltage drops at every terminal/connection or just clean em ALL from battery in/thru bulkhead/under dash connections/out thru bulkhead. Check/clean ground path also. EDIT For a chemical to aid in cleaning reportedly "Deoxit" is VG for cleaning terminals (I'm gonna try it). Not sure who sells it but it'd be easy to find out
