On the fuel pump- Early pumps would blow past 100 psi, later pumps and aftermarket top out at 70-85 psi.
You are having a low boost issue and the fuel pressure is fine, I think you are chasing a red herring at this point and you should focus on other areas.
A pound or two of fuel pressure will make no difference, these cars are not that sensitive to it.
I'd start with the basics- check your cam and distributor timing and go from there.
