So you need a $100k car to go 10.80's?.....Sorry not sold on them....
On your next 10 second pass crank the wheel as hard as you can to the left while grabbing the large disc brakes, then turn on the AC tell the GPS where you want dinner and drive straight there with all the White Snake you can handle hearing. I'm sure all of our old cars are capable lmao
??? I could go buy a 2011 Mustang GT add some boost and get that done pretty quick. Probably could do a used SRT-8 Charger as well. I'm also guessing it could be done for well under 100k on one of our old school rides. 100k is a lot of money.
Here y'all go: http://www.civicforums.com/forums/194-ve...er-reduced.html
You can probably pick up this Honda for $2,000 add about $10,000 worth of engine/tranny/rear/suspension and go 10.50 all for under $15,000. That will meet your goal easily!
