Quote: Do you have a Passon 5 speed? If so, that is what the car needs to really be a dual threat. Have Doctor Diff change the 2.94 rear gears over to something in the upper 3's, add the Passon 5 speed and that car becomes a fire breather.
AndyF, do you feel it's a bit compromised and undergeared for the track currently? Or overgeared for the street? Or?
Did Tim get to take it on the track with the Milodon pan and new sway bar setup?
The car is set up right now for PIR so the torque curve matches the track speed of approx. 60 mph on the tight corner to 150-160 mph down the front straight. That is why is has the super tall rear end gears. The super tall rear end gears are a little tough on the clutch life when driving around town.
Some 3.70 or 3.90 rear gears with a Passon 5 speed would make the car a stop light monster and still give it 160 mph top speed capability. It was one of things that we wanted to do with the car but just didn't have the budget. Hopefully the Passon 5 speed can handle the torque output of the 427. If so, then the car would be a serious threat to any Vette or Viper.
