Glycol is death on bearings.
8v92 Detroits were famous for losing their liner seals and dumping coolant in the base. The low coolant light usually came on at the same time it spun all the crank bearings.
Kevin
All the block flaws where fixed before I built it the first time, no Glycol in these bearings
