Re: Motor carnage pictures, UGLY!
[Re: WadeMetzinger]
#1639010
06/27/14 04:21 PM
06/27/14 04:21 PM
Posts: 43,312 Bend,OR USA
Cab_Burge
Can you offset grind the crank to 4 3/8 or 4 1/2 and move to Chevy 2.2 journal and reuse the crank?
That is a possibility, depending on how bad the crank is hurt. It is a older Crower top fuel crank so maybe it is saveable I did find three cylinders that have small holes in the bottom from debris That block is toast as far as I'm concenred I'm working him up a quote for a new short block using a 4.5 bore World block with new crank, roods and pistons. He is in a hurry so time will be the deciding factor on who's part I use on this build, it will be a pump gas motor around 540 + C.I. so he can still stay on the tens It ran mid to low tens before at 496 C.I.(I think that is hte number with 4.25 stroke, 4.310 bore). I'm still baffled about what failed first or what caused the #1 rod bearing to spin OH,WELL I'm still learning, hopefully
Entire Thread
Cab_Burge
06/27/14 06:14 AM
Cab_Burge
06/27/14 06:15 AM
goldmember
06/27/14 06:19 AM
MR_P_BODY
06/27/14 06:20 AM
tex013
06/27/14 08:01 AM
gregsdart
06/27/14 09:30 AM
tubtar
06/27/14 10:24 AM
Moparmal
06/27/14 12:21 PM
MRMOPAR622
06/27/14 02:19 PM
Mr.Yuck
06/27/14 02:39 PM
pittsburghracer
06/27/14 03:05 PM
CTD5.9
06/27/14 05:24 PM
Monte_Smith
06/27/14 06:04 PM
WadeMetzinger
06/27/14 07:05 PM
Cab_Burge
06/27/14 08:21 PM
AndyF
06/27/14 09:42 PM
lorenr
06/27/14 09:43 PM
Quicktree
06/27/14 10:21 PM
Cab_Burge
06/27/14 10:27 PM
onig
06/27/14 11:03 PM
Twostick
06/28/14 12:03 AM
onig
06/28/14 01:27 AM
nss guy
06/28/14 02:38 AM
Cab_Burge
06/28/14 06:12 PM
Cab_Burge
06/28/14 06:13 PM
onig
06/29/14 02:41 AM
Cab_Burge
06/29/14 05:02 AM
Airwoofer
06/30/14 04:28 PM
Cab_Burge
06/30/14 06:28 PM
Airwoofer
06/30/14 06:40 PM
Twostick
06/30/14 08:05 PM
Bigbeep
06/29/14 08:37 PM
cudaman1969
06/29/14 10:52 PM
Thumperdart
06/29/14 11:51 PM
Mopar_Rich
06/30/14 12:03 AM
Cab_Burge
06/30/14 03:35 AM
cudadon
06/27/14 03:41 PM
dartman366
06/27/14 05:13 PM
AndyF
06/27/14 05:48 PM
Thumperdart
06/27/14 05:59 PM
440Jim
06/28/14 03:03 AM
Cab_Burge
06/28/14 04:49 AM
Twostick
06/28/14 05:06 AM
TonyS451
06/28/14 05:02 PM
Cab_Burge
06/28/14 06:16 PM
Kern Dog
06/28/14 06:27 PM
J_BODY
06/28/14 06:28 PM
