Already have the HV pump from the last rebuilt engine with only 15k on it, so I'm running it. Pressure was 25-35 PSI @idle hot, 65 PSI at hi RPM using straight 30W
As for the rear main seal, I did some research, and looks like knurled=rope, smooth=lip. My crank being stock, is most likely knurled.
