Should run good, however you might be better off w/ more jet especailly on the primary. A 750DP would be a better choice. I'm guessing you're running a 4.5PV??? What slick will you be using, because if you are palnning on running it w/ street radials....it's not going to work. You should be ok in the compression area, That cam tends to bleed compression some. Did you install it straight up? most guys like to run them 4* advanced. My old 67, I miss it.
