Install the carrier and the axles and set the bearing end play. Make sure you pack the axle bearings as these are not lubed by the gear oil. Once you get it all buttoned up, pull the fill plug and fill it up. Should take about 2 1/4 quarts. 80W/90 will work fine. Add Limited slip additive if its a sure grip. Done!!
