If you look through the big hole in the axle you will see it is used to get to the 5 bolts holding the axle in. Remove those bolts and pull the axles out about 4" and you can drop the pumpkin out the front. After you remove the nuts holding it on the rearend housing of course. What are you having your buddy do to it?
