Quote: Remove all the nuts, Tap the snout of the housing left & right with a rubber hammer or large block of wood. This will break the bond of the gasket and the 3rd member can be lifted right out.
For 'easy' carrying of the 3rd member, put the U-bolt of an exhaust clamp through the top bolthole nearest to the large gear and thread a nut on it so it won't slip out. This way you'll have a nice balanced handle to lift the 3rd member by and carry it around, posing to the chicks across the street or something.
I believe I have a rubber mallet at home. Lol. I mean, I can almost carry the whole differential drum-to-drum by myself, I can't see why I can't do a carrier.
